Use the following procedure to determine the data stream learned when IP multicast is configured on the VLAN.
- Select Multicast.
- Select the Routes tab.
Routes Field Descriptions
Use the data in the following table to use the Routes tab.
Name |
Description |
Group |
Displays the IP multicast group address for this entry that contains multicast routing information. |
Source |
Displays the network address that, when combined with the corresponding route SourceMask value, identifies the source that contains multicast routing information. |
SourceMask |
Displays the network mask that, when combined with the corresponding route Source value, identifies the multicast source. |
UpstreamNeighbor |
Shows the address of the upstream neighbor from which the IP datagrams from these sources are received. The address is 0.0.0.0 if the network is local. |
Interface |
Displays the interface, slot and portnumber, or VLAN ID where IP datagrams sent by these multicast sourcesto this multicast address are received. |
ExpiryTime |
Displays the amount of time that remains before this entry ages out. The value 0 indicates that the entry is not subject to aging. |
Protocol |
Displays the protocol as one of the following:
